주요 콘텐츠로 건너뛰기
Samsung Galaxy Gear Band Replacement
필요한 것
  1. Samsung Galaxy Gear Band Replacement, Display Housing: 1 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Band Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Band Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Gear Band Replacement: 3 단계, 이미지 2/2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Band Replacement, Band: 4 단계, 이미지 1/1
    • Loosen the camera ribbon so it will easily pass through the watch body.
  5. Samsung Galaxy Gear Band Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Gear Band Replacement: 5 단계, 이미지 2/2
    • Grip the body of the watch and pull the band upward.
    • Do the same with the adjacent band, but there will be no camera ribbon to pass through the watch body.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Dalt Lasell
회원 가입일: 04/12/16
543 평판
안내서 2개 작성하였습니다
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 회원
CPSU-MANESS-S16S1G9
4 회원들
안내서 7개 작성하였습니다
댓글 8개
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Naji Ajaleel Ibrahim - 답글
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Roger Palmer - 답글
Please advise are you able to ship to Pakistan
Mehboob Mehmood - 답글
These are very helpful but could do with one more step and pic at the end - for how to swap out the embedded camera.
Dan Bloch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 30
전체 시간: 18,596
