이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
To replace the watch band on your device, you will need to remove the band. This is demonstrated by the following steps. Removing the band also assists in removing the camera from the device.
필요한 것
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 8개
I have the non camera band (the one with holes )to be changed only. .... but I don't know where to buy it from and how to make sure that it will be the right one for this model SM- v700
Naji
Is there a shop in London where I can have this Band changed and repaired by themselves ?
Naji
Absolutely brilliant instructions. Many thanks.
On mine two of the screws were T5 Torx and the other two were T6 Torx, so something to look for.
Please advise are you able to ship to Pakistan
