주요 콘텐츠로 건너뛰기
Samsung Galaxy Gear Battery Replacement
필요한 것
  1. Samsung Galaxy Gear Battery Replacement, Display Housing: 1 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Gear Battery Replacement: 3 단계, 이미지 2/2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Battery Replacement, Battery: 4 단계, 이미지 1/2 Samsung Galaxy Gear Battery Replacement, Battery: 4 단계, 이미지 2/2
    • After separating the LCD/motherboard from the actual watch itself, the watch should be in two separate pieces.
    • You will only need the watch/strap component so you can set aside the LCD/motherboard component.
  5. Samsung Galaxy Gear Battery Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Gear Battery Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Gear Battery Replacement: 5 단계, 이미지 3/3
    • Look for the metal bracket that covers and secures the battery in place.
    • Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
    • The battery should now be exposed.
  6. Samsung Galaxy Gear Battery Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Gear Battery Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Gear Battery Replacement: 6 단계, 이미지 3/3
    • Notice the leads attached to the base of the watch. You will need to remove this before you pull the battery out.
    • Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
    • Slowly tug on the "PULL" tag and remove the battery from the watch.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Edward Yi
회원 가입일: 04/11/16
424 평판
안내서 1개 작성함
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 회원
CPSU-MANESS-S16S1G9
4 회원들
안내서 7개 작성하였습니다
댓글 4개
WHERE DO I GET A NEW bATTERY & THE TOOLS; IS A COMPLETE KIT AVAILABLE?
rbilello - 답글
where do I get the battery & tools
steve ellis - 답글
“Parts
No parts required.”
I think a battery is required!
cyberjoe3d - 답글
Thank you very much
Adam P NYC
bori0916adam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 13,316
