주요 콘텐츠로 건너뛰기
Samsung Galaxy Gear Motherboard Replacement
필요한 것
  1. Samsung Galaxy Gear Motherboard Replacement, Display Housing: 1 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Gear Motherboard Replacement: 3 단계, 이미지 2/2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Samsung Galaxy Gear Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
  5. Samsung Galaxy Gear Motherboard Replacement: 5 단계, 이미지 1/1
    • The motherboard is attached to the display using an adhesive
    • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
  6. Samsung Galaxy Gear Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Gear Motherboard Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
    • Slowly pry up the motherboard from the display.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joe
회원 가입일: 04/11/16
279 평판
안내서 2개 작성하였습니다
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 회원
CPSU-MANESS-S16S1G9
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Had to build a cradle, keep breaking, do not know out the 5 brass pronges which is pisitive and negative, how is there no schematic of the gear watch??
Chris martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 2,572
