주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, SIM and Memory Cards: 1 단계, 이미지 3개 중 3개
    • This is Samsung Galaxy Grand Neo Plus i9060i with broken screen.
    • Remove the battery and any installed SIM and memory cards.
  2. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 1: 2 단계, 이미지 3개 중 3개
    • There are 12x small Phillips screws, remove them.
    • With a plastic tool start the disassembling from the bottom side.
    • You can use more then one plastic tool.
  3. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 2: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Rear Cover 2: 3 단계, 이미지 2개 중 2개
    • The rear bezel is locked to the frame near to the battery connector. Use a tool with a sharp tip and unhook it.
    • Now you can separate the rear bezel.
    • This is the Loudspeaker (in case if you want to change it).
  4. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Logic Board: 4 단계, 이미지 3개 중 3개
    • Remove one Phillips screw.
    • Disconnect:
    • Vloume UP/DWN buttons flex cable and Power ON button flex cable.
    • LCD flex cable
    • Front camera
    • Audio jack flex cable
    • Now gently remove the logic board.
  5. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Front Camera: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Front Camera: 5 단계, 이미지 2개 중 2개
    • Remove the front camera.
    • Disconnect the touchscreen flex cable and unstuck it from the middle frame.
  6. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 1: 6 단계, 이미지 3개 중 3개
    • At the bottom side, under the touch screen glass is the menu buttons flex cable. Be careful for it when you separating the glass from the frame.
    • Warm the glass. This will soften the adhesive tape. You can use hot air gun or hair dryer.
    • With a plastic tool start the separation at the upper side.
  7. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Touch Screen Removal - Part 2: 7 단계, 이미지 3개 중 3개
    • You can warm the glass again to separate the glass easier.
    • Gently unstuck the menu buttons flex cable and remove the glass.
  8. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Cleaning: 8 단계, 이미지 3개 중 3개
    • There is a small plate in the touch screen flex cable slot. Remove it to allow the flex cable of the new touch screen to pass.
    • Remove the remnants of the adhesive sticker and clean the LCD.
  9. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement, Installation of the new Touch Screen: 9 단계, 이미지 3개 중 3개
    • Install the new touch screen and start with the reassembling.
  10. Samsung Galaxy Grand Neo Plus Touch screen Digitizer Glass Replacement: 10 단계, 이미지 1개 중 1개
    • That's all. Thanks!
결론
다른 29명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,135 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
326 회원들
안내서 1,670개를 작성함
1 Guide Comment
very much helpful..this guide saved my repairing charge...this page is awesome..
Pravesh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 16
전체 시간: 16,869
