주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Battery Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Battery Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy Grand Prime Battery Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy Grand Prime Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 2 단계, 이미지 1/3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 2 단계, 이미지 2/3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 2 단계, 이미지 3/3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
결론
다른 51명이 해당 안내서를 완성하였습니다.
Damien Harris
회원 가입일: 02/04/16
978 평판
안내서 1개 작성함
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G3
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
Noelu Toyotomi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 22
30일 전: 91
전체 시간: 14,027
