이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This repair is needed to replace the dead battery in your device if it does not turn on, hold a charge, or just flat out wont charge at all.
필요한 것
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
다른 51명이 해당 안내서를 완성하였습니다.
댓글 한 개
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
