주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Digitizer and LCD Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Remove the battery.: 2 단계, 이미지 3개 중 3개
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Midframe: 3 단계, 이미지 3개 중 3개
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 4 단계, 이미지 2개 중 2개
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 5 단계, 이미지 2개 중 2개
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Digitizer and LCD: 6 단계, 이미지 1개 중 1개
    • Disconnect all flex cables and remove the motherboard and the front-facing camera.
    • The display assembly is attached to the frame with adhesive.
    • Insert an opening pick between the glass and the frame in the gap above the front-facing camera bracket. Begin to slice through the adhesive on the top bezel of the phone.
  7. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 7 단계, 이미지 2개 중 2개
    • On the right corner, gently twist the pick up and down to further separate the adhesive, then insert it as shown between the LCD and the frame.
    • Insert a second pick into the gap between the frame and the display flex cable.
    • Move both picks towards the bottom of the phone to separate the adhesive on the sides of the screen.
  8. Samsung Galaxy Grand Prime Digitizer and LCD Replacement: 8 단계, 이미지 1개 중 1개
    • Apply heat to the bottom bezel, then insert a pick between the frame and the digitizer.
    • To avoid damaging the home button, ensure the pick goes above it as shown.
    • The home button may fall out.
  9. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Removing the screen assembly: 9 단계, 이미지 1개 중 1개
    • Separate the adhesive on the bottom half of the phone, flip it around, and separate the frame from the screen assembly starting from the bottom.
    • Ensure the display cable can freely move through the hole in the frame.
    • The ear speaker grille may fall out.
  10. Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Separating the LCD and digitizer: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Digitizer and LCD Replacement, Separating the LCD and digitizer: 10 단계, 이미지 2개 중 2개
    • The LCD and digitizer are not glued together with LOCA glue, but just with adhesive around the edges of the digitizer.
    • The digitizer is connected to the LCD with a flex cable. Flip up the bottom half of the connector.
    • Apply gentle heat to the IC. Insert a pick as shown and separate.
    • To separate the LCD and digitizer, apply gentle heat to the front of the assembly and gently slide picks along the edges of the LCD.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Patrick
회원 가입일: 05/14/14
6,767 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 41
전체 시간: 2,409
