주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Removing back cover: 1 단계, 이미지 1개 중 1개
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The Battery: 2 단계, 이미지 1개 중 1개
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The SD And LCD Ribbon Cable: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Remove The SD And LCD Ribbon Cable: 3 단계, 이미지 2개 중 2개
    • To remove the SD card and Sim card, look above the battery bay and slide the card out.
    • Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
  4. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Removing screws: 4 단계, 이미지 1개 중 1개
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
    • Keep the screws on a magnetic mat or in a secure location.
  5. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Seperating Bezel and Screen: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement, Seperating Bezel and Screen: 5 단계, 이미지 2개 중 2개
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to separate.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  6. Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Grand Prime Headphone Jack and Loudspeaker Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone.
    • You do not need to remove the motherboard to do this.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Alex Boyle
회원 가입일: 07/31/18
374 평판
안내서 3개를 작성함
UW Tacoma, Team S1-G1, Liner Summer 2018 UW Tacoma, Team S1-G1, Liner Summer 2018 회원
UWT-LINER-SU18S1G1
5 회원들
안내서 5개를 작성함
0 Guide Comments
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 52
전체 시간: 1,652
