주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 2 단계, 이미지 1/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 2 단계, 이미지 2/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 2 단계, 이미지 3/3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 3 단계, 이미지 1/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 3 단계, 이미지 2/3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 3 단계, 이미지 3/3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 4 단계, 이미지 2/2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 5 단계, 이미지 2/2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 1/2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 2/2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
결론
다른 30명이 해당 안내서를 완성하였습니다.
Kyle Ruff
회원 가입일: 02/04/16
6,749 평판
안내서 5개 작성하였습니다
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G3
3 회원들
안내서 12개 작성하였습니다
댓글 3개
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - 답글
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - 답글
How to me a memory card a default storage on grand prime
Ayandaundetsco - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 48
전체 시간: 36,057
