주요 콘텐츠로 건너뛰기
Samsung Galaxy Grand Prime Micro USB Port Replacement
필요한 것
  1. Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 2 단계, 이미지 1/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 2 단계, 이미지 2/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Remove the battery.: 2 단계, 이미지 3/3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 3 단계, 이미지 1/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 3 단계, 이미지 2/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Midframe: 3 단계, 이미지 3/3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Micro USB Port Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 4 단계, 이미지 2/2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Micro USB Port Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 5 단계, 이미지 2/2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Headphone Jack/Speaker Assembly: 6 단계, 이미지 2/2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
  7. Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 7 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Earpiece Speaker: 7 단계, 이미지 2/2
    • Use the plastic opening tool to unhook the ribbon cable clip.
  8. Samsung Galaxy Grand Prime Micro USB Port Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 8 단계, 이미지 2/2
    • Gently pull on the connector with the tweezers until the speaker comes off.
  9. Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 9 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement, Motherboard: 9 단계, 이미지 2/2
    • Unhook the other ribbon cable clip to the screen with the blue plastic opening tool.
  10. Samsung Galaxy Grand Prime Micro USB Port Replacement: 10 단계, 이미지 1/3 Samsung Galaxy Grand Prime Micro USB Port Replacement: 10 단계, 이미지 2/3 Samsung Galaxy Grand Prime Micro USB Port Replacement: 10 단계, 이미지 3/3
    • Unhook the ribbon cable clip to the front camera.
    • Lift the motherboard up and out of the device.
  11. Samsung Galaxy Grand Prime Micro USB Port Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Grand Prime Micro USB Port Replacement: 11 단계, 이미지 2/2
    • Remove the motherboard and unhook the ribbon cable clip to the back camera.
  12. Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 12 단계, 이미지 1/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 12 단계, 이미지 2/3 Samsung Galaxy Grand Prime Micro USB Port Replacement, Micro USB Port: 12 단계, 이미지 3/3
    • Using a soldering iron to solder off the charging port.
    • Be careful soldering iron gets extremely hot.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Kyle Ruff
회원 가입일: 02/04/16
6,725 평판
안내서 5개 작성하였습니다
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 39
전체 시간: 34,757
