주요 콘텐츠로 건너뛰기
Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: 1 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: 1 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement, Touch Screen & LCD: 1 단계, 이미지 3개 중 3개
    • Here we have Samsung Galaxy J1 with broken glass and screen.
    • We will replace the touch screen and the LCD.
    • First remove the battery and any installed SIM and memory cards.
  2. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 2 단계, 이미지 3개 중 3개
    • Under this plastic is the LCD flex cable connector.
    • Use a tool with a needlepoint and remove it.
  3. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the LCD flex cable.
    • When I can, I always test new replacement part before I install it.
  4. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 4 단계, 이미지 3개 중 3개
    • Use hot air to warm the glass and to make adhesive soften.
    • With a cutter or knife start the separation.
    • When you have enough space between the glass and the frame, continue with a plastic tool.
  5. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 5 단계, 이미지 3개 중 3개
    • You can warm the glass again to make the separation more easy.
    • If you want to change only the touch screen, be careful, don't break the LCD.
    • Finally remove the screen and the glass from the frame.
  6. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 6 단계, 이미지 3개 중 3개
    • If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
  7. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 7 단계, 이미지 3개 중 3개
    • Connect the touch screen to the LCD flex cable.
    • Put the LCD and the screen in their place.
    • Remove the protector from the touch screen.
    • Install the earpiece metal plate - take it from the old touch screen.
    • Remove the protector from the LCD (if it's new).
  8. Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 8 단계, 이미지 2개 중 1개 Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement: 8 단계, 이미지 2개 중 2개
    • Connect the LCD flex cable and you are ready.
결론
다른 114명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,943 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
25가이드 댓글
Bonjour, ou peux t on trouver l'écran et la vitre de protection ? Merci d'avance
Romain - 답글
How much is the cost for Galaxy J1 replacement glass?
Charles Young - 답글
It costs from 18€ up to 25€.
Johannes Franzen -
none of my inventions are that price
nikola tesla -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 96
전체 시간: 149,665
