소개
How to disassemble and replace the Touch screen digitizer and the LCD display.
필요한 것
동영상 개요
Here we have Samsung Galaxy J1 with broken glass and screen.
We will replace the touch screen and the LCD.
First remove the battery and any installed SIM and memory cards.
Under this plastic is the LCD flex cable connector.
Use a tool with a needlepoint and remove it.
다른 113명이 해당 안내서를 완성하였습니다.
댓글 24개
Thank you ifixit
How much is the cost for Galaxy J1 replacement glass?
It costs from 18€ up to 25€.
Gracias bro .. se ve interesante el único problema es que no se muy bien el ingles
Hello!Need wholesale LCD screen?https://txlcd.com/
Samnsung j1 SM-j111M
I can't find replacemnt for Samnsung j1 SM-j111M?
do you know what model it is compatible with it?
Not charge contineu
Why is it that replacing the touch and LCD is so expensive
Why is it that
I have put a new screen on my friends Samsung galaxy J1 but it won't turn on and when it dose I'll see are lines. What do I do?
Very helpful, thank you!
Jess Price - 답글
Is J1 LCD is compatible with J1 Ace model J110H ?
Samsung j1ace full screen replacement
thank for posting, genial consejo
