주요 콘텐츠로 건너뛰기
Samsung Galaxy J1 Glass Screen Replacement
필요한 것
  1. Samsung Galaxy J1 Glass Screen Replacement, Midframe: 1 단계, 이미지 1/1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Glass Screen Replacement: 2 단계, 이미지 1/2 Samsung Galaxy J1 Glass Screen Replacement: 2 단계, 이미지 2/2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Glass Screen Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Glass Screen Replacement: 4 단계, 이미지 1/3 Samsung Galaxy J1 Glass Screen Replacement: 4 단계, 이미지 2/3 Samsung Galaxy J1 Glass Screen Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: 5 단계, 이미지 1/2 Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: 5 단계, 이미지 2/2
    • Using the flat end of a spudger, disconnect the digitizer cable connector.
  6. Samsung Galaxy J1 Glass Screen Replacement: 6 단계, 이미지 1/2 Samsung Galaxy J1 Glass Screen Replacement: 6 단계, 이미지 2/2
    • Using a plastic opening tool pry between silver digitizer and black back piece.
    • Slowly slide plastic opening tool around the screen to loosen the adhesive.
    • Be careful not to tear the digitizer cable when threading it through the plastic housing.
  7. Samsung Galaxy J1 Glass Screen Replacement: 7 단계, 이미지 1/1
    • Carefully separate display assembly from the plastic housing.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Sean Kramer
회원 가입일: 02/14/18
1,506 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G4
3 회원들
안내서 6개 작성하였습니다
댓글 2개
In my Samsung J110h, Some of the right side keys in keyboard not working. They are P, Zero, In message screen, the sending button etc..
I am in desperate need for advice to rectify.
Will somebody help me.
My mail Id”: karupusolai@gmail.com
Solaimalai - 답글
I was having the display issue. So I bought Samsung Galaxy J1 Screen replacement. And, I replaced it by myself using the information in this.
harshithaemazel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 68
전체 시간: 4,843
