주요 콘텐츠로 건너뛰기
Samsung Galaxy J1 Midframe Replacement
필요한 것
  1. Samsung Galaxy J1 Midframe Replacement, Midframe: 1 단계, 이미지 1/1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Midframe Replacement: 2 단계, 이미지 1/2 Samsung Galaxy J1 Midframe Replacement: 2 단계, 이미지 2/2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Midframe Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Midframe Replacement: 4 단계, 이미지 1/3 Samsung Galaxy J1 Midframe Replacement: 4 단계, 이미지 2/3 Samsung Galaxy J1 Midframe Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sean Kramer
회원 가입일: 02/14/18
1,506 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 25
전체 시간: 2,167
