주요 콘텐츠로 건너뛰기
Samsung Galaxy J1 Motherboard Replacement
필요한 것
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: 1 단계, 이미지 1/1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: 4 단계, 이미지 1/3 Samsung Galaxy J1 Motherboard Replacement: 4 단계, 이미지 2/3 Samsung Galaxy J1 Motherboard Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: 9 단계, 이미지 1/3 Samsung Galaxy J1 Motherboard Replacement: 9 단계, 이미지 2/3 Samsung Galaxy J1 Motherboard Replacement: 9 단계, 이미지 3/3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: 10 단계, 이미지 1/1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: 11 단계, 이미지 1/2 Samsung Galaxy J1 Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the rear camera.
결론
다른 22명이 해당 안내서를 완성하였습니다.
Sean Kramer
회원 가입일: 02/14/18
1,467 평판
안내서 6개 작성하였습니다
USF Tampa, Team S5-G4, Eyestone Spring 2018 USF Tampa, Team S5-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G4
3 회원들
안내서 6개 작성하였습니다
댓글 4개
can you plz give use a amazon link to part
Sean Gynn - 답글
Very good illustration..where can I get a motherboard?
Isaac Samuels - 답글
Where can I get a motherboard for this phone Samsung J100?
Isaac Samuels - 답글
I need the details of the motherboard
FUN FIRST - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 47
전체 시간: 6,657
