주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Eclipse Motherboard Replacement
필요한 것
  1. Samsung Galaxy J3 Eclipse Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the phone face down on its screen.
  2. Samsung Galaxy J3 Eclipse Motherboard Replacement: 2 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 2 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull up on the small indention on the right side edge and remove the back portion of the phone.
  3. Samsung Galaxy J3 Eclipse Motherboard Replacement: 3 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 3 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 3 단계, 이미지 3/3
    • After removing the back of the device, locate the slot below the bottom right corner of the battery and use the tip of your finger to remove it.
  4. Samsung Galaxy J3 Eclipse Motherboard Replacement, Display Assembly: 4 단계, 이미지 1/1
    • Use a heat gun or hair dryer to heat up the front edges of the phone for about two minutes. Stay approximately six inches away from the screen to prevent phone damage.
    • Do not apply heat to any one edge of the phone for longer than a few seconds. Instead, use a continuous motion around the phone's edges.
  5. Samsung Galaxy J3 Eclipse Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Galaxy J3 Eclipse Motherboard Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • While the screen adhesive is still warm and flexible, insert a pry tool or plastic card between the glass display and the frame of the phone.
    • Slowly slide another pry tool around all the edges of the phone in order to break the adhesive's bond to the display.
    • When using the pry tool, do not use too much force or the phone's internals could be damaged.
    • Do not insert your tool more than 1cm into the top edge of the phone to avoid damaging the fragile cables.
  6. Samsung Galaxy J3 Eclipse Motherboard Replacement: 6 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 6 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 6 단계, 이미지 3/3
    • Gently lift lower side and loosen all edges to hinge screen up from bottom.
    • Do not try to completely remove the display from the frame yet. Simply try to loosen up all the edges.
  7. Samsung Galaxy J3 Eclipse Motherboard Replacement: 7 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 7 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 7 단계, 이미지 3/3
    • Use your prying tool to slowly pry up on the bottom right corner of the white cable guard, exposing a thin ribbon cable connector.
  8. Samsung Galaxy J3 Eclipse Motherboard Replacement: 8 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 8 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement: 8 단계, 이미지 3/3
    • Pry up the ribbon cable connector revealed from under the cable guard and remove the display from the device.
    • Clean the residue from the phone edges before re-assembling phone with new screen.
  9. Samsung Galaxy J3 Eclipse Motherboard Replacement, Audio Jack: 9 단계, 이미지 1/3 Samsung Galaxy J3 Eclipse Motherboard Replacement, Audio Jack: 9 단계, 이미지 2/3 Samsung Galaxy J3 Eclipse Motherboard Replacement, Audio Jack: 9 단계, 이미지 3/3
    • Locate all eleven screws attaching the metal plate to the frame, and remove them using a PH00 screwdriver bit.
    • Keep track of the eleven screws they are essential to close the phone back again.
  10. Samsung Galaxy J3 Eclipse Motherboard Replacement: 10 단계, 이미지 1/2 Samsung Galaxy J3 Eclipse Motherboard Replacement: 10 단계, 이미지 2/2
    • While holding the phone , flip it to the back side and use your two thumbs to push on the metal area where the battery was, this should release the back frame from the device.
  11. Samsung Galaxy J3 Eclipse Motherboard Replacement: 11 단계, 이미지 1/2 Samsung Galaxy J3 Eclipse Motherboard Replacement: 11 단계, 이미지 2/2
    • Locate the blue ribbon cable attached just below the battery slot . This is the connector for your audio jack.
    • Use your pry tool to release the cable from the motherboard
결론
To reassemble your device, reconnect all cables and follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Chandler Casey
회원 가입일: 09/21/18
792 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 644
