주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Emerge Speaker Replacement
필요한 것
  1. Samsung Galaxy J3 Emerge Speaker Replacement, Screen: 1 단계, 이미지 1/3 Samsung Galaxy J3 Emerge Speaker Replacement, Screen: 1 단계, 이미지 2/3 Samsung Galaxy J3 Emerge Speaker Replacement, Screen: 1 단계, 이미지 3/3
    • Heat up the edges of the screen with a hair dryer.
    • Put the iFixit Opening Tool between the screen and body to open the edge of the screen up.
    • Work the iFixit Opening Tools around the whole screen to break the glue.
  2. Samsung Galaxy J3 Emerge Speaker Replacement: 2 단계, 이미지 1/2 Samsung Galaxy J3 Emerge Speaker Replacement: 2 단계, 이미지 2/2
    • Lift the screen up from the bottom.
    • The screen could crack when lifting it up.
    • Pry the gray cover open.
  3. Samsung Galaxy J3 Emerge Speaker Replacement: 3 단계, 이미지 1/2 Samsung Galaxy J3 Emerge Speaker Replacement: 3 단계, 이미지 2/2
    • Pry the connector off of the motherboard by using a clean nail or the iFixit opening tool.
  4. Samsung Galaxy J3 Emerge Speaker Replacement, Motherboard: 4 단계, 이미지 1/2 Samsung Galaxy J3 Emerge Speaker Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the eleven Phillips #00 3.5mm screws.
    • If the screws get stuck when removing, try using tape to get them out. Place the adhesive side of tape on the screws and pull the tape off the spot.
  5. Samsung Galaxy J3 Emerge Speaker Replacement: 5 단계, 이미지 1/1
    • Turn the phone over and push down where the battery was.
    • There will be a loud clicking noise when applying pressure.
  6. Samsung Galaxy J3 Emerge Speaker Replacement: 6 단계, 이미지 1/1
    • Insert the iFixit Opening Pick between the motherboard and the panel.
    • Work the iFixit Opening Pick around the outside of the motherboard.
  7. Samsung Galaxy J3 Emerge Speaker Replacement: 7 단계, 이미지 1/2 Samsung Galaxy J3 Emerge Speaker Replacement: 7 단계, 이미지 2/2
    • Pry the motherboard away from the phone using your hand.
  8. Samsung Galaxy J3 Emerge Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Samsung Galaxy J3 Emerge Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the iFixit Opening Pick to pry off the speaker from the back side.
    • Pull out speaker with hands or use tweezers to pull out speaker.
결론
Hugh Cosculluela
회원 가입일: 01/24/19
507 평판
안내서 4개 작성하였습니다
Cal Poly, Team S19-G2, White Winter 2019 Cal Poly, Team S19-G2, White Winter 2019 회원
CPSU-WHITE-W19S19G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 940
