소개
This guide will describe how to remove and replace the home key on the Samsung Galaxy J3.
필요한 것
Separate the back casing from the phone by carefully using your fingers to pry them apart.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
