주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Luna Pro Front and Back Camera Replacement
필요한 것
  1. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Motherboard Change: 1 단계, 이미지 1/1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 2 단계, 이미지 1/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 2 단계, 이미지 2/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 2 단계, 이미지 3/3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 3 단계, 이미지 1/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 3 단계, 이미지 2/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 3 단계, 이미지 3/3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 4 단계, 이미지 1/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 4 단계, 이미지 2/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 4 단계, 이미지 3/3
    • Remove the eleven JIS 00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 5 단계, 이미지 1/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 5 단계, 이미지 2/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement: 5 단계, 이미지 3/3
    • Remove the motherboard from the mid-frame.
  6. Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: 6 단계, 이미지 1/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: 6 단계, 이미지 2/3 Samsung Galaxy J3 Luna Pro Front and Back Camera  Replacement, Front and Back Camera: 6 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flaps on the front and rear camera ribbon cable ZIF sockets.
    • Pull the cables outs of the ZIF sockets.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jay Patel
회원 가입일: 01/29/18
150 평판
안내서 1개 작성함
USF Tampa, Team S5-G5, Passmore Spring 2018 USF Tampa, Team S5-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 1,344
