주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Mission Midframe Replacement
필요한 것
  1. Samsung Galaxy J3 Mission Midframe Replacement, Back Cover: 1 단계, 이미지 1/1
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Midframe Replacement, Battery: 2 단계, 이미지 1/1
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Midframe Replacement, SD and SIM Cards: 3 단계, 이미지 1/1
    • Use your finger to slide the SD and SIM card out of the device.
  4. Samsung Galaxy J3 Mission Midframe Replacement, Screen: 4 단계, 이미지 1/1
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
  5. Samsung Galaxy J3 Mission Midframe Replacement, Midframe: 5 단계, 이미지 1/2 Samsung Galaxy J3 Mission Midframe Replacement, Midframe: 5 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove all eleven 5mm screws from the metal panel.
  6. Samsung Galaxy J3 Mission Midframe Replacement: 6 단계, 이미지 1/1
    • Turn the device over, and push firmly to separate the metal plate from the back paneling.
결론
Joseph Toth
회원 가입일: 09/21/18
686 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 6
전체 시간: 496
