주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Mission Screen Replacement
필요한 것
  1. Samsung Galaxy J3 Mission Screen Replacement, Back Cover: 1 단계, 이미지 1/1
    • Insert your fingernail into the back cover removal slot and gently pull back until the cover pops off.
  2. Samsung Galaxy J3 Mission Screen Replacement, Battery: 2 단계, 이미지 1/1
    • Make sure that your device is powered off before removing the battery.
    • Insert your fingernail into the battery removal slot and pull back until the battery pops out.
  3. Samsung Galaxy J3 Mission Screen Replacement, Screen: 3 단계, 이미지 1/1
    • Use an iFixit opening tool to lift the screen from one of the vertical sides of the phone and continue gently prying until the screen is loose enough to safely remove.
    • The damaged screen is connected under the screen assembly with a small plastic brace; remove this with an iFixit opening tool.
    • Be careful around the home button. It has little tabs to keep it in the frame, but they will break if the adhesive isn’t loosened with age or heat.
결론
To install a new screen try the connector before adding any adhesive, then put it back together by following these steps in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
Joseph Toth
회원 가입일: 09/21/18
686 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,917
