주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 Motherboard Replacement
필요한 것
  1. Samsung Galaxy J3 Motherboard Replacement, Back Cover Removal: 1 단계, 이미지 1/1
    • Unplug the device from the charging dock if it is connected. Power off the device. Then using your fingernails, pop off the back cover of the device.
  2. Samsung Galaxy J3 Motherboard Replacement, Battery Removal: 2 단계, 이미지 1/1
    • Remove the battery from the casing.
  3. Samsung Galaxy J3 Motherboard Replacement, Main Body Removal: 3 단계, 이미지 1/1
    • Remove the screws using a Philips #00 screwdriver .
    • Remember to keep your screws organized!
  4. Samsung Galaxy J3 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy J3 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a metal spudger, pry the mid frame out.
    • Do not use a wrenching motion or the screen will crack.
  5. Samsung Galaxy J3 Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy J3 Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy J3 Motherboard Replacement: 5 단계, 이미지 3/3
    • Use a spudger or your fingernails to disconnect the screen connector.
    • Use a spudger or your fingernails to disconnect the connector cable.
  6. Samsung Galaxy J3 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard.
    • It should come off easily, if not, some screws might still be connected.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sophie
회원 가입일: 09/20/17
291 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 40
전체 시간: 8,910
