주요 콘텐츠로 건너뛰기
Samsung Galaxy J3V Power Button Replacement
필요한 것
  1. Samsung Galaxy J3V Power Button Replacement, Power Button: 1 단계, 이미지 1/3 Samsung Galaxy J3V Power Button Replacement, Power Button: 1 단계, 이미지 2/3 Samsung Galaxy J3V Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
  2. Samsung Galaxy J3V Power Button Replacement: 2 단계, 이미지 1/3 Samsung Galaxy J3V Power Button Replacement: 2 단계, 이미지 2/3 Samsung Galaxy J3V Power Button Replacement: 2 단계, 이미지 3/3
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
  3. Samsung Galaxy J3V Power Button Replacement: 3 단계, 이미지 1/3 Samsung Galaxy J3V Power Button Replacement: 3 단계, 이미지 2/3 Samsung Galaxy J3V Power Button Replacement: 3 단계, 이미지 3/3
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
  4. Samsung Galaxy J3V Power Button Replacement: 4 단계, 이미지 1/2 Samsung Galaxy J3V Power Button Replacement: 4 단계, 이미지 2/2
    • After opening the phone, locate the power button on the back frame of the phone.
  5. Samsung Galaxy J3V Power Button Replacement: 5 단계, 이미지 1/3 Samsung Galaxy J3V Power Button Replacement: 5 단계, 이미지 2/3 Samsung Galaxy J3V Power Button Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the power button's rubber tabs from the clips holding them.
    • Gently remove the entire button
결론
Carry Corrales
회원 가입일: 09/28/17
738 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G3, Nance Fall 2017 USF Tampa, Team S3-G3, Nance Fall 2017 회원
USFT-NANCE-F17S3G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 1,110
