주요 콘텐츠로 건너뛰기
Samsung Galaxy J6 Display Replacement
필요한 것
  1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: 1 단계, 이미지 1/3 Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: 1 단계, 이미지 2/3 Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: 1 단계, 이미지 3/3
    • I recommend wearing eye protection to avoid any inconvenience with glass fragments.
    • It is very important to heat the display on the side parts where the double-sided adhesive is well with a hairdryer or other so as to make it lose its adhesion and facilitate the operation of inserting the blade to lift it.
    • Insert the blade between the body and the glass and begin to separate the display from the body, I recommend starting from the top paying attention.
    • The flat connection connectors are located at the bottom.
  2. Samsung Galaxy J6 Display Replacement, Lift up the display: 2 단계, 이미지 1/2 Samsung Galaxy J6 Display Replacement, Lift up the display: 2 단계, 이미지 2/2
    • Lift the display.
  3. Samsung Galaxy J6 Display Replacement, Remove the display: 3 단계, 이미지 1/3 Samsung Galaxy J6 Display Replacement, Remove the display: 3 단계, 이미지 2/3 Samsung Galaxy J6 Display Replacement, Remove the display: 3 단계, 이미지 3/3
    • Unplug the black plastic plug securing the display connector.
    • Unhook the display connector.
    • Remove the old display and place the new display.
    • Put some glue to attach the new display.
결론
다른 41명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Smilzo
회원 가입일: 11/09/13
11,276 평판
안내서 39개 작성하였습니다
댓글 10개
f**k this adhesive!!
Thanks for this tutorial :)
NoCheatImPGM - 답글
Gli adesivi non aderiscono bene sono d’accordo,puoi provare con altro biadesivo 3M oppure con della colla idonea.
Smilzo -
You mentioned nothing about disconnecting the battery. If the phone accidentally turns on in the middle of a display swap [with no way to turn it off, since there’s no display or digitser connected] you will blow an internal fuse, rendering the phone useless. Complete waste of time! You should have included that the battery be disconnected before attempting this.
Dot - 답글
Ciao ti ringrazio per la Puntualizzazione ed il buon consiglio.
io non ho mai avuto problemi nello scollegare i display perché il telefono è precedentemente spento e rimane spento fino a quando non scollego il connettore display.
se per sfortuna si dovesse toccare il tasto power (che comunque richiede una lunga pressione e non un semplice tocco ) si vedrebbe accendere il display o vibrare il telefono o accendersi i led. Quindi prima di scollegare lo spegnerei nuovamente.
non vedo il problema.
scollegare la batteria comporta una procedura analoga a togliere il display e quindi molto tempo in più ed accollarsi i rischi di rompere un componente posteriore per rimuoverlo,perdendo così impermeabilità se non si dispone di adesivo specifico per questa sostituzione.
Smilzo -
Ciao e grazie della guida.
Quale modello di display e su quale sito consigli di comprarlo?
Danilo B. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 62
30일 전: 298
전체 시간: 15,522
