필요한 것
It is very important to heat the display on the side parts where the double-sided adhesive is well with a hairdryer or other so as to make it lose its adhesion and facilitate the operation of inserting the blade to lift it.
Insert the blade between the body and the glass and begin to separate the display from the body, I recommend starting from the top paying attention.
The flat connection connectors are located at the bottom.
Lift the display.
This photo does not show the original glue strip round the edge of the bezel. When you try to lift the screen the glue strip will be stuck to the glass is some areas and the the bezel in others. The 3 strips shown are not orriginal!
Unplug the black plastic plug securing the display connector.
Unhook the display connector.
Remove the old display and place the new display.
Put some glue to attach the new display.
Double sided tape might work but does not provide the same level of sealing round the edge of the screen. Any wetness round the screen will wick under and get into the electronics. You should use a new properly shaped glue strip.
다른 41명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 10개
f**k this adhesive!!
Thanks for this tutorial :)
Gli adesivi non aderiscono bene sono d’accordo,puoi provare con altro biadesivo 3M oppure con della colla idonea.
Smilzo -
You mentioned nothing about disconnecting the battery. If the phone accidentally turns on in the middle of a display swap [with no way to turn it off, since there’s no display or digitser connected] you will blow an internal fuse, rendering the phone useless. Complete waste of time! You should have included that the battery be disconnected before attempting this.
Ciao ti ringrazio per la Puntualizzazione ed il buon consiglio.
io non ho mai avuto problemi nello scollegare i display perché il telefono è precedentemente spento e rimane spento fino a quando non scollego il connettore display.
se per sfortuna si dovesse toccare il tasto power (che comunque richiede una lunga pressione e non un semplice tocco ) si vedrebbe accendere il display o vibrare il telefono o accendersi i led. Quindi prima di scollegare lo spegnerei nuovamente.
non vedo il problema.
scollegare la batteria comporta una procedura analoga a togliere il display e quindi molto tempo in più ed accollarsi i rischi di rompere un componente posteriore per rimuoverlo,perdendo così impermeabilità se non si dispone di adesivo specifico per questa sostituzione.
Smilzo -
Ciao e grazie della guida.
Quale modello di display e su quale sito consigli di comprarlo?
Ciao Danilo generalmente faccio una ricerca su eBay per rendermi conto del prezzo,se è accettabile proseguo con il pagamento sicuro grazie a PayPal visto che è un mercato sicuro come lo è Amazon, anche se ho verificato che in genere sono un po’ più alti i prezzi di Amazon però sono veloci le consegne tendenzialmente
Smilzo -
Buongiorno, il biadesivo quanto deve essere spesso? 1mm? E come in foto, va messo solo nel punto ribassato dove non c’è la piastra d’acciaio? Grazie
Ciao,in teoria dovrebbe bastare soltanto sui bordi se il display è originale ovvero piatto,se trovi i compatibili lcd sono più alti anche se costano meno e sono una rogna da farli stare giu. Se metti il biadesivo anche al centro se devi toglierlo per qualche motivo è quasi certo che romperai il pannello. Valuta tu,magari prova a metterlo solo nei bordi e se non ti accontenta poi lo, metti anche dietro al pannello,oppure puoi usare la colla b7000 che ha un’ottima presa. Buona riparazione
Smilzo -
Samsung J6+ battery change
Idris Oped - 답글
