소개
In this guide you will find out how to replace display in your Galaxy J7 2017 smartphone. Follow the tutorial to avoid any damage to your device.
필요한 것
다른 17명이 해당 안내서를 완성하였습니다.
댓글 10개
The screen is pretty cheap and costs around 15$.
You can find it on ebay.com
Does replacing the LCD reset the phone?
No it doesn’t. You can safely replace the lcd without loosing the data. Best luck!
The best option is b7000, strong enough for such a job.
mine is screwed up it won’t let me do anything it acts like the touch screen is off it just keeps going up & down to eack thing on the phone i can’t get to settings or anything
You need to check if it is a display or logic board issue.
