필요한 것
Locate the Tab: Find the tab at the top left corner of the back cover. (highlighted by red square)
Insert the tool: Use a fingernail or a plastic opening tool to lift the tab gently
Pry open the cover: Carefully work around the edges to remove the back cover completely
Locate the Battery slot: Find the small slit at the bottom right corner of the battery (highlighted by red square)
Remove Battery: Gently pop out the edge and carefully pull out the battery.
Using the Phillips #000 screwdriver, remove the ten 4.2 mm screws around the edge of the midframe.
다른 2명이 해당 안내서를 완성하였습니다.
