주요 콘텐츠로 건너뛰기
Samsung Galaxy J7 v Volume Button Replacement
필요한 것
  1. Samsung Galaxy J7 v Volume Button Replacement, Screen: 1 단계, 이미지 1/1
    • Be very careful during this step. The OLED (organic light-emitting diode) display is very fragile and can break easily.
    • Insert a Jimmy tool under one of the corners of the display and gently raise the display.
  2. Samsung Galaxy J7 v Volume Button Replacement: 2 단계, 이미지 1/1
    • Gently slide the Jimmy tool around the entire perimeter of the phone.
  3. Samsung Galaxy J7 v Volume Button Replacement: 3 단계, 이미지 1/1
    • Be extra careful with the display's ribbon cables. They are fragile.
    • Carefully lift the display to remove it.
  4. Samsung Galaxy J7 v Volume Button Replacement, Home button: 4 단계, 이미지 1/1
    • Locate the socket of the home button.
    • Fit the metal spudger in between the socket and the home button.
  5. Samsung Galaxy J7 v Volume Button Replacement: 5 단계, 이미지 1/1
    • Take the metal spudger and slide it underneath the home button.
    • Lift up until the home button is removed from its socket.
  6. Samsung Galaxy J7 v Volume Button Replacement, Volume Button: 6 단계, 이미지 1/2 Samsung Galaxy J7 v Volume Button Replacement, Volume Button: 6 단계, 이미지 2/2
    • Remove the screws around the home button and the screws above.
  7. Samsung Galaxy J7 v Volume Button Replacement: 7 단계, 이미지 1/1
    • Pull the screen away from the panel.
  8. Samsung Galaxy J7 v Volume Button Replacement: 8 단계, 이미지 1/2 Samsung Galaxy J7 v Volume Button Replacement: 8 단계, 이미지 2/2
    • Remove all adjacent screws.
  9. Samsung Galaxy J7 v Volume Button Replacement: 9 단계, 이미지 1/3 Samsung Galaxy J7 v Volume Button Replacement: 9 단계, 이미지 2/3 Samsung Galaxy J7 v Volume Button Replacement: 9 단계, 이미지 3/3
    • Pop off panel from plastic hold.
  10. Samsung Galaxy J7 v Volume Button Replacement: 10 단계, 이미지 1/3 Samsung Galaxy J7 v Volume Button Replacement: 10 단계, 이미지 2/3 Samsung Galaxy J7 v Volume Button Replacement: 10 단계, 이미지 3/3
    • Use the pointed end of the spudger to push down the button hold, then the volume button can be removed by pushing it down.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Somtoo Chukwurah
회원 가입일: 03/05/19
305 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 24
전체 시간: 884
