주요 콘텐츠로 건너뛰기
Samsung Galaxy Light Earpiece Speaker Replacement
필요한 것
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: 1 단계, 이미지 1/1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: 4 단계, 이미지 1/1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 5 단계, 이미지 1/3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 5 단계, 이미지 2/3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: 5 단계, 이미지 3/3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: 6 단계, 이미지 1/2 Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Paul Goyette
회원 가입일: 10/21/14
475 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 678
