주요 콘텐츠로 건너뛰기
Samsung Galaxy Light Motherboard Replacement
필요한 것
  1. Samsung Galaxy Light Motherboard Replacement, Remove Back Cover: 1 단계, 이미지 1개 중 1개
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Motherboard Replacement, Remove Battery: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the device.
  3. Samsung Galaxy Light Motherboard Replacement, Unscrew Midframe: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Motherboard Replacement, Remove Midframe: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Light Motherboard Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 3개
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Diandra
회원 가입일: 10/16/14
210 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 1,328
