주요 콘텐츠로 건너뛰기
Samsung Galaxy Light Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Back Cover: 1 단계, 이미지 1개 중 1개
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Battery: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the device.
  3. Samsung Galaxy Light Rear Facing Camera Replacement, Unscrew Midframe: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Rear Facing Camera Replacement, Remove Midframe: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Light Rear Facing Camera Replacement, Detach Motherboard: 5 단계, 이미지 3개 중 3개
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
92,023 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 649
