주요 콘텐츠로 건너뛰기
Samsung Galaxy Light USB Charging Port Replacement
필요한 것
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: 1 단계, 이미지 1/1
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: 2 단계, 이미지 1/1
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: 3 단계, 이미지 1/1
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 4 단계, 이미지 1/3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 4 단계, 이미지 2/3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: 4 단계, 이미지 3/3
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: 5 단계, 이미지 1/2 Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: 5 단계, 이미지 2/2
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
결론
다른 3명이 해당 안내서를 완성하였습니다.
Diandra
회원 가입일: 10/16/14
210 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 3개
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - 답글
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - 답글
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 1,100
