주요 콘텐츠로 건너뛰기
Samsung Galaxy Luna LCD display Replacement
필요한 것
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: 1 단계, 이미지 1/1
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: 2 단계, 이미지 1/1
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: 3 단계, 이미지 1/1
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Luna LCD display Replacement: 4 단계, 이미지 2/2
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Luna LCD display Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Luna LCD display Replacement: 5 단계, 이미지 3/3
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
결론
다른 2명이 해당 안내서를 완성하였습니다.
xingyu chen
회원 가입일: 02/14/18
266 평판
안내서 1개 작성함
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G1
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - 답글
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,001
