이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
Place the spudger tool between the LCD and the glass screen.
Slide the spudger tool in between the screen and the display until both are completely separated from each other.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Hola, cual es el numero de parte de la pantalla a reemplazar?
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
