주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Luna Motherboard Replacement
필요한 것
  1. Samsung Galaxy Luna Motherboard Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry the divot to the left of the camera to take off the rear case.
  2. Samsung Galaxy Luna Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the corner nearest to the divot to remove the case from the phone.
  3. Samsung Galaxy Luna Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Place your fingernail or a prying tool at the bottom of the battery and pry it out of the case.
  4. Samsung Galaxy Luna Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • By using your finger or a plastic opening tool, push the SIM card further into its container until a click is heard.
    • Once the click is heard grab the SIM card and slide it out of the container.
    • Remove the SIM card completely.
    • During reassembly, slide the new SIM card into the slot until a click is heard.
  5. Samsung Galaxy Luna Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Luna Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Luna Motherboard Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool, or your fingernail to to take off the rear case by prying the divot to the left of the camera.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Using an opening tool, take off the cover for the digitizer connector.
    • detach the connector with a tweezer or a plastic spudger.
  6. Samsung Galaxy Luna Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Luna Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Place small suction cup on the center of screen and press firmly.
    • Hold the back of the phone and pull on the suction cup gently until the screen begins to bend.
  7. Samsung Galaxy Luna Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the small metal spudger into an opening on the phone and pry off the screen.
    • Avoid tearing any exposed circuits as the screen is being removed.
    • Make sure the screen is completely detached from the motherboard before removing it.
  8. Samsung Galaxy Luna Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using a Philips PH000 screwdriver, remove the nine 3 mm screws.
  9. Samsung Galaxy Luna Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Using a metal spudger, gently pry the button frame off the motherboard.
    • Do the same for the motherboard.
    • Avoid scraping the circuitry on the motherboard, as they can be very fragile.
  10. Samsung Galaxy Luna Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Luna Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Luna Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Using a Philips PH000 screwdriver, remove the black screw.
    • Use the metal spudger to pry open the motherboard cover.
    • Be careful when prying the cover of the motherboard. avoid scratching the motherboard circuitry.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jahina Al Balushi
회원 가입일: 02/14/18
188 평판
안내서 1개를 작성함
USF Tampa, Team S6-G1, Eyestone Spring 2018 USF Tampa, Team S6-G1, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 31
전체 시간: 933
