주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy M51 Screen Replacement
필요한 것
  1. Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: 1 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: 1 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM eject tool into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy M51 Screen Replacement, Heat an iOpener: 2 단계, 이미지 1개 중 1개
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover for at least two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy M51 Screen Replacement, Create an opening gap: 3 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement, Create an opening gap: 3 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement, Create an opening gap: 3 단계, 이미지 3개 중 3개
    • Apply a suction handle to the back cover, as close to the USB-C port as possible.
    • Lift the back cover's bottom edge with your suction handle, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created.
    • Slide the opening pick to the bottom left corner and leave it there.
  4. Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: 4 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: 4 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it from the bottom left corner to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy M51 Screen Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a third opening pick under the bottom right corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide it along the right edge of the phone to the top right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy M51 Screen Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the left corner to cut the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  7. Samsung Galaxy M51 Screen Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick on the top left corner and slide it along the edge to cut the remaining adhesive.
  8. Samsung Galaxy M51 Screen Replacement, Remove the back cover: 8 단계, 이미지 1개 중 1개
    • Remove the back cover.
  9. Samsung Galaxy M51 Screen Replacement, Disconnect the fingerprint sensor: 9 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement, Disconnect the fingerprint sensor: 9 단계, 이미지 2개 중 2개
    • Use the pointy end of a spudger to disconnect the fingerprint sensor from the motherboard.
  10. Samsung Galaxy M51 Screen Replacement, Remove the screws: 10 단계, 이미지 1개 중 1개
    • Remove the 15 4.0 mm-long Phillips #00 screws securing the midframe.
  11. Samsung Galaxy M51 Screen Replacement, Release the plastic clips: 11 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement, Release the plastic clips: 11 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement, Release the plastic clips: 11 단계, 이미지 3개 중 3개
    • The midframe is held by plastic clips.
    • Insert an opening pick between midframe and display near the usb-c port.
    • Slide the opening pick to bottom right corner to release the plastic clips.
  12. Samsung Galaxy M51 Screen Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the opening pick along the right edge to release the plastic clips.
  13. Samsung Galaxy M51 Screen Replacement: 13 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 13 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge to release the midframe from the plastic clips.
  14. Samsung Galaxy M51 Screen Replacement: 14 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 14 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Slide the opening pick along the left edge to release the plastic clips.
  15. Samsung Galaxy M51 Screen Replacement, Remove the midframe: 15 단계, 이미지 1개 중 1개
    • Remove the midframe.
  16. Samsung Galaxy M51 Screen Replacement, Battery Disconnect: 16 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement, Battery Disconnect: 16 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the battery.
  17. Samsung Galaxy M51 Screen Replacement, Disconnect the screen: 17 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement, Disconnect the screen: 17 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to disconnect the display cable from the daughterboard.
  18. Samsung Galaxy M51 Screen Replacement, Heat an iOpener: 18 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • The adhesive is placed on the edges of the display. Make sure that the iOpener covers all edges and repeat the heating process if necessary.
  19. Samsung Galaxy M51 Screen Replacement, Create an opening gap: 19 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement, Create an opening gap: 19 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement, Create an opening gap: 19 단계, 이미지 3개 중 3개
    • Apply a suction handle near the bottom edge.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Insert an opening pick into the gap between display and the frame.
  20. Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: 20 단계, 이미지 2개 중 1개 Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: 20 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
  21. Samsung Galaxy M51 Screen Replacement: 21 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 21 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Insert a third opening pick and slide it along the left edge to cut the adhesive.
    • Leave the opening pick on the top right corner.
  22. Samsung Galaxy M51 Screen Replacement: 22 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 22 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 22 단계, 이미지 3개 중 3개
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough to cut the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert a fourth opening pick and slide it to the top left corner to cut the adhesive.
  23. Samsung Galaxy M51 Screen Replacement: 23 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 23 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 23 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick and slide it along the left edge to cut the remaining adhesive.
  24. Samsung Galaxy M51 Screen Replacement: 24 단계, 이미지 3개 중 1개 Samsung Galaxy M51 Screen Replacement: 24 단계, 이미지 3개 중 2개 Samsung Galaxy M51 Screen Replacement: 24 단계, 이미지 3개 중 3개
    • Thread the display cable through the frame.
  25. Samsung Galaxy M51 Screen Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the display.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
66,732 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,685개를 작성함
11가이드 댓글
Vielen Dank, für diese Anleitung! Ich würde auch gerne diese Anleitung nutzen, um mein kaputtes Display selbst zu tauschen, jedoch finde ich in den Weiten des Internets kein Ersatzglas für das M51. Kann mir jemand einen passenden link nennen? Da ich nichts passendes gefunden habe, wäre meine nächste Frage, ob das Display vom S20 Plus kompatibel wäre, da es die gleichen Maße misst..?Vielen Dank im voraus!
Vg
Marv
Marv Zockt - 답글 공유
Hi,
such mal nach einem M515 Display-Glas. Das ist kompatibel.
Mfg
Mr. Jingels - 답글 공유
Merci beaucoup !
Grâce à vous j’ai pu changer moi même l’écran de la collègue amie de ma mère et elle va être très heureuse !
Vous apportez de la joie, et vos tutos sont vraiment de qualité bravo !
Antoine
Antoine HIEZELY - 답글 공유
Is a71 screen compatible with m51?
abodeabodeabode60 - 답글 공유
Humko abhi sikna hai
shanihasnain912 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 152
전체 시간: 15,058
