주요 콘텐츠로 건너뛰기
Samsung Galaxy Media Player 5 Earpiece Speaker Replacement
필요한 것
  1. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 1 단계, 이미지 2개 중 2개
    • Remove the SD Memory Card before working on the device.
    • Use a Phillips screwdriver to remove the 10 mm screw near the SD Memory Card port.
  2. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • White caps cover screws on both sides of the charging port. Use the angled tweezers to remove them.
    • Use a blow dryer on low heat if necessary to loosen the adhesive.
  3. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Phillips head screwdriver, unscrew the two 10 mm screws located on either side of the charging port.
  4. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Using the opening pick, pry at the bottom and work around each edge of the device until the front cover and back cover housing is separated.
    • You will hear a popping sound to indicate the separation.
  5. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, apply an upward force to detach the battery and the tab attached to it.
  6. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, apply an upward force to detach the speaker earpiece.
    • Use the tweezers to attach the new earpiece speaker in place of the original.
    • Use a blow dryer, on low heat settings, to loosen the adhesive on the speaker earpiece.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
China Ayala
회원 가입일: 03/05/15
596 평판
안내서 4개를 작성함
Sam Houston State, Team 11-7, Blackburne Winter 2015 Sam Houston State, Team 11-7, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G7
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 538
