주요 콘텐츠로 건너뛰기
Samsung Galaxy Media Player 5 Earpiece Speaker Replacement
필요한 것
  1. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 1 단계, 이미지 1/2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement, Earpiece Speaker: 1 단계, 이미지 2/2
    • Remove the SD Memory Card before working on the device.
    • Use a Phillips screwdriver to remove the 10 mm screw near the SD Memory Card port.
  2. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 2 단계, 이미지 1/1
    • White caps cover screws on both sides of the charging port. Use the angled tweezers to remove them.
    • Use a blow dryer on low heat if necessary to loosen the adhesive.
  3. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 3 단계, 이미지 2/2
    • Using a Phillips head screwdriver, unscrew the two 10 mm screws located on either side of the charging port.
  4. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 4 단계, 이미지 3/3
    • Using the opening pick, pry at the bottom and work around each edge of the device until the front cover and back cover housing is separated.
    • You will hear a popping sound to indicate the separation.
  5. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, apply an upward force to detach the battery and the tab attached to it.
  6. Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 1/3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 2/3 Samsung Galaxy Media Player 5 Earpiece Speaker Replacement: 6 단계, 이미지 3/3
    • Using the plastic opening tool, apply an upward force to detach the speaker earpiece.
    • Use the tweezers to attach the new earpiece speaker in place of the original.
    • Use a blow dryer, on low heat settings, to loosen the adhesive on the speaker earpiece.
결론
다른 2명이 해당 안내서를 완성하였습니다.
China Ayala
회원 가입일: 03/05/15
584 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 11-7, Blackburne Winter 2015 Sam Houston State, Team 11-7, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 374
