주요 콘텐츠로 건너뛰기
Samsung Galaxy Mega (SGH-M819N) Front Display Assembly Replacement
필요한 것
동영상 개요
  1. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove battery and rear door.: 1 단계, 이미지 1/2 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove battery and rear door.: 1 단계, 이미지 2/2
    • bold textWith a heavily shattered screen lay some tape over it to protect yourself and to keep it all in one place.
    • Flip the phone over to remove the batter door and battery.
  2. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove Phillips Screws and Speaker componant.: 2 단계, 이미지 1/2 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove Phillips Screws and Speaker componant.: 2 단계, 이미지 2/2
    • With a phillips remove all 14 visibile screws.
    • Using your pry tool slowly pop the speaker companant off.being careful not to damage it
  3. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 3 단계, 이미지 1/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 3 단계, 이미지 2/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove rear assembly frame: 3 단계, 이미지 3/3
    • Using the pry tool work your way arounf the phone, separating the rear assembly frame from the device.
    • the frame can be deceiving and seem as if it attached closer to the top but in the picture you will see down to the middle is where you should look to separate.
    • Fully remove the rear assembly frame from the main device.
  4. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 4 단계, 이미지 1/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 4 단계, 이미지 2/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove the LCD Cable and the Front Camera: 4 단계, 이미지 3/3
    • Using a spudger or pry tool lift remove the LCD flex cable from the logic board.
    • Next with a phillips screwdriver remove the one screw holding the protection plate over the cameras,
    • Proceed to remove the front camera
  5. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 5 단계, 이미지 1/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 5 단계, 이미지 2/3 Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Using heat to soften the adhesive: 5 단계, 이미지 3/3
    • With your heat hun slowly heat the screen while using pry tool to work your wau around the device.
    • With atleast 3 guitar pick keeping separation as you progress the screen should slowly start lifting off.
    • leave the bottom area for last and be careful with your tools to not damage the back cable.
  6. Samsung Galaxy Mega  (SGH-M819N) Front Display Assembly Replacement, Remove bad LCD: 6 단계, 이미지 1/1
    • Clean device then follow the steps in reverse.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Austin Pollard
회원 가입일: 02/05/17
1,474 평판
안내서 3개 작성하였습니다
Reno Phone Repair Reno Phone Repair 회원
Business
1 회원
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 14
전체 시간: 1,680
