소개
This repair guide will give a basic demonstration of how to remove the battery from a Galaxy Mega 2. The repair is fairly simple and does not take too much time. It involves removing the back cover and replacing the battery.
필요한 것
On the back of the phone, find the slot at the charging port located at the bottom of the phone.
Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
Once you get the corner released, slide your finger around the outside until the back cover releases.
다른 3명이 해당 안내서를 완성하였습니다.
