주요 콘텐츠로 건너뛰기
Samsung Galaxy Mega 2 Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Mega 2 Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/1
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Locate the battery.
    • Use pry tool or fingernail to lift up on the battery.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use phillips head PH000 and remove all 13, 1.4 mm screws as shown.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use tweezers to disconnect the digitizer.
  4. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 4 단계, 이미지 3/3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off, completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
  5. Samsung Galaxy Mega 2 Front Facing Camera Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: 5 단계, 이미지 3/3
    • Locate the camera in the top left corner.
    • Lift the motherboard connector and remove the camera assembly from phone.
결론
Taylor Powell
회원 가입일: 09/08/17
753 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 720
