소개
This repair guide demonstrates how to replace the LCD/Digitizer on the Galaxy Mega 2. The repair involves removing the screen in order to get to the LCD. A few screws must be removed in order to take out the part.
필요한 것
On the back of the phone, find the slot at the charging port located at the bottom of the phone.
Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
Once the corner is released, slide your finger around the outside until the back cover releases.
Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
Once heated, gently pull the screen upward.
다른 3명이 해당 안내서를 완성하였습니다.
