주요 콘텐츠로 건너뛰기
Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement
필요한 것
  1. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement, Screen & Digitizer Assembly: 1 단계, 이미지 1/1
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
  2. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 2 단계, 이미지 2/2
    • Locate the battery.
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery.
  3. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 3 단계, 이미지 1/3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 3 단계, 이미지 2/3 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 3 단계, 이미지 3/3
    • Use a phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
  4. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 4 단계, 이미지 2/2
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
  5. Samsung Galaxy Mega 2 Screen & Digitizer Assembly Replacement: 5 단계, 이미지 1/1
    • Now, seperate the screen from the outside frame of the phone (the bezel).
결론
다른 3명이 해당 안내서를 완성하였습니다.
Taylor Powell
회원 가입일: 09/08/17
753 평판
안내서 5개 작성하였습니다
댓글 한 개
I want to repair my phone
Monirul Islam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 1,261
