주요 콘텐츠로 건너뛰기
Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement
필요한 것
  1. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 2 단계, 이미지 3개 중 3개
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Midframe: 3 단계, 이미지 3개 중 3개
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement, Earpiece Speaker/LED Indicator: 5 단계, 이미지 1개 중 1개
    • Remove the black 2.55 mm Phillips #000 screw.
  6. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the metal cover with the plastic opening tool.
  7. Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Mega Earpiece Speaker/LED Indicator Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard clip from speaker assembly to the motherboard.
    • Gently lift the speaker and LED assembly out of the device.
    • Speaker assembly may be glued to the device, gently pry until it releases.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Max Rathman
회원 가입일: 02/04/16
915 평판
안내서 4개를 작성함
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G2
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,186
