주요 콘텐츠로 건너뛰기
Samsung Galaxy Nexus Back Camera Lens Replacement
필요한 것
  1. Samsung Galaxy Nexus Back Camera Lens Replacement, Back of Phone: 1 단계, 이미지 1개 중 1개
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Back Cover: 2 단계, 이미지 3개 중 3개
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement, Removal of Battery: 3 단계, 이미지 3개 중 3개
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
  5. Samsung Galaxy Nexus Back Camera Lens Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement: 5 단계, 이미지 3개 중 3개
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
  6. Samsung Galaxy Nexus Back Camera Lens Replacement, Removing Control Board: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement, Removing Control Board: 6 단계, 이미지 2개 중 2개
    • Unscrew 4.4mm with a PH #000 marked screw.
  7. Samsung Galaxy Nexus Back Camera Lens Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 7 단계, 이미지 2개 중 2개
    • With the flat head screw driver pull up the blue connector.
  8. Samsung Galaxy Nexus Back Camera Lens Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement: 8 단계, 이미지 3개 중 3개
    • With you finger or prying tool pull back bottom module.
  9. Samsung Galaxy Nexus Back Camera Lens Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
  10. Samsung Galaxy Nexus Back Camera Lens Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 10 단계, 이미지 2개 중 2개
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
  11. Samsung Galaxy Nexus Back Camera Lens Replacement: 11 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 11 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the antenna using either your fingers or tweezers.
  12. Samsung Galaxy Nexus Back Camera Lens Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy Nexus Back Camera Lens Replacement: 12 단계, 이미지 3개 중 3개
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
  13. Samsung Galaxy Nexus Back Camera Lens Replacement, Back Camera Lens: 13 단계, 이미지 2개 중 1개 Samsung Galaxy Nexus Back Camera Lens Replacement, Back Camera Lens: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers pull out the back camera lens from the circuit board.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Stephan Williams
회원 가입일: 09/22/14
1,482 평판
안내서 7개를 작성함
1가이드 댓글
Main picture of camera is off center.
Dan Brown - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 41
전체 시간: 1,307
