소개
This guide is here to help you replace the battery of your Samsung Galaxy Nexus.
필요한 것
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
다른 12명이 해당 안내서를 완성하였습니다.
