주요 콘텐츠로 건너뛰기
Samsung Galaxy Nexus Main Display Glass Replacement
필요한 것
  1. Samsung Galaxy Nexus Main Display Glass Replacement, Removing Back Cover: 1 단계, 이미지 1/1
    • Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
    • Remove the battery by prying it free from the divot at the bottom.
    • Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
  2. Samsung Galaxy Nexus Main Display Glass Replacement: 2 단계, 이미지 1/1
    • Remove the four 4.5 mm Phillips screws from the rear of the phone.
  3. Samsung Galaxy Nexus Main Display Glass Replacement: 3 단계, 이미지 1/2 Samsung Galaxy Nexus Main Display Glass Replacement: 3 단계, 이미지 2/2
    • Flip the phone over so that the screen faces upward.
    • Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
    • Slowly pry the outer case from the screen.
    • Work carefully. Excessive force can easily damage the case.
  4. Samsung Galaxy Nexus Main Display Glass Replacement: 4 단계, 이미지 1/3 Samsung Galaxy Nexus Main Display Glass Replacement: 4 단계, 이미지 2/3 Samsung Galaxy Nexus Main Display Glass Replacement: 4 단계, 이미지 3/3
    • Remove a single 4 mm Phillips #00 screw from the bottom of the phone.
    • Lift up the flat connector from its socket on the motherboard.
    • Lift the entire headphone jack assembly from the phone.
  5. Samsung Galaxy Nexus Main Display Glass Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Nexus Main Display Glass Replacement: 5 단계, 이미지 2/2
    • Disconnect the two ribbon cables from the motherboard.
  6. Samsung Galaxy Nexus Main Display Glass Replacement: 6 단계, 이미지 1/1
    • Using tweezers or a spudger, lift the vibrator motor from its recess in the midframe.
  7. Samsung Galaxy Nexus Main Display Glass Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Nexus Main Display Glass Replacement: 7 단계, 이미지 2/2
    • Using tweezers, gently disconnect the antenna cable from its socket on the motherboard.
  8. Samsung Galaxy Nexus Main Display Glass Replacement: 8 단계, 이미지 1/2 Samsung Galaxy Nexus Main Display Glass Replacement: 8 단계, 이미지 2/2
    • Use tweezers to pull the motherboard out of the phone.
    • Work carefully. Depending on the model, the underside of the motherboard may still have ribbon cables connecting it to the display assembly.
  9. Samsung Galaxy Nexus Main Display Glass Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Nexus Main Display Glass Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Nexus Main Display Glass Replacement: 9 단계, 이미지 3/3
    • Starting near the USB port, use your tweezers to pull the small daughterboard from the phone.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Carmine Tenaglia
회원 가입일: 09/15/13
320 평판
안내서 1개 작성함
Oakland University, Team 1-17, Ruszkiewicz Fall 2013 Oakland University, Team 1-17, Ruszkiewicz Fall 2013 회원
OAK-RUSZKIEWICZ-F13S1G17
1 회원
안내서 1개 작성하였습니다
댓글 2개
with this guide , I found this repair easy to do. Thank you Tom G.
Thomas Giles - 답글
Deberían d3 poner los diagramas eléctricos para reparar gracias
manchadoshow - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 10
전체 시간: 20,681
