주요 콘텐츠로 건너뛰기
Samsung Galaxy Nexus Motherboard Replacement
필요한 것
  1. Samsung Galaxy Nexus Motherboard Replacement, Back of Phone: 1 단계, 이미지 1/1
    • You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
  2. Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: 2 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: 2 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Back Cover: 2 단계, 이미지 3/3
    • Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
  3. Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: 3 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: 3 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement, Removal of Battery: 3 단계, 이미지 3/3
    • Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
    • This is when a new battery will be inserted.
  4. Samsung Galaxy Nexus Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Remove 4.4 mm screws using a PH # 000 as indicated on the picture.
    The screws need to be labeled with the head type and the length.
    Spencer - 답글
    Confusing heading.
    Dan Brown - 답글
    This is something that cannot be fixed. Due to it being a prerequisite guide it comes up with the title of the guide itself as it is inserted as a prerequisite guide.
    Stephan Williams -
  5. Samsung Galaxy Nexus Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement: 5 단계, 이미지 3/3
    • After removing the screws be sure to turn the phone right side up.
    • Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
    • Pop the screen out of the outer shell. Be cautious not to damage the control board or the screen.
  6. Samsung Galaxy Nexus Motherboard Replacement, Removing Control Board: 6 단계, 이미지 1/2 Samsung Galaxy Nexus Motherboard Replacement, Removing Control Board: 6 단계, 이미지 2/2
    • Unscrew 4.4mm with a PH #000 marked screw.
    Add head type for screw.
    Dan Brown - 답글
  7. Samsung Galaxy Nexus Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Galaxy Nexus Motherboard Replacement: 7 단계, 이미지 2/2
    • With the flat head screw driver pull up the blue connector.
    flat-head? flat head?
    Dan Brown - 답글
    Don't omit articles.
    Dan Brown - 답글
  8. Samsung Galaxy Nexus Motherboard Replacement: 8 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement: 8 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement: 8 단계, 이미지 3/3
    • With you finger or prying tool pull back bottom module.
    You should add a step to pry off the connection on the side of the board also.
    Spencer - 답글
    Change "pulled back" to "pull back."
    Dan Brown - 답글
  9. Samsung Galaxy Nexus Motherboard Replacement: 9 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement: 9 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the internal battery using tweezers or your flat head screw driver.
    • There is glue at the bottom keeping battery and chassis stuck together.
  10. Samsung Galaxy Nexus Motherboard Replacement: 10 단계, 이미지 1/2 Samsung Galaxy Nexus Motherboard Replacement: 10 단계, 이미지 2/2
    • Peel the display connector strip off the main circuit board using the tweezers.
    • Peel the USB connector strip off the main circuit board using the tweezers.
    There are 2 tabs that need to be disconnected, not just one.
    Spencer - 답글
  11. Samsung Galaxy Nexus Motherboard Replacement: 11 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement: 11 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove the antenna using either your fingers or tweezers.
  12. Samsung Galaxy Nexus Motherboard Replacement: 12 단계, 이미지 1/3 Samsung Galaxy Nexus Motherboard Replacement: 12 단계, 이미지 2/3 Samsung Galaxy Nexus Motherboard Replacement: 12 단계, 이미지 3/3
    • Using tweezers, pull the top circuit board off.
    • Depending on your model, there may be ribbon cable connectors attached to the underside of the board. Be careful not to rip them out of the sockets when removing the board.
    Last photo is blurry.
    Dan Brown - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Stephan Williams
회원 가입일: 09/22/14
1,482 평판
안내서 7개 작성하였습니다
댓글 2개
I believe the blue tool needs to be called the "plastic opening tool."
Dan Brown - 답글
were i can find mother board i need the mother board
bangera.kaushik990 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 4,054
