이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
You must open the back of the phone to access the battery. To do this use the plastic opening tools or your fingernail and insert it into the divot.
Remove the back cover of the phone by moving the prying tool or your fingernail away from the phone while it is still in the divot.
Insert your finger into the divot of the battery and pull the battery towards yourself to remove.
This is when a new battery will be inserted.
After removing the screws be sure to turn the phone right side up.
Insert your plastic opening tool between the screen and the outer case. Move the opening tool around the phone without removing it from in between the screen and the shell of the phone.
Remove the internal battery using tweezers or your flat head screw driver.
Peel the display connector strip off the main circuit board using the tweezers.
Peel the USB connector strip off the main circuit board using the tweezers.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
were i can find mother board i need the mother board
